This command configures VLAN Authorization for a port, port list, or all ports.
| port_list | List of ports to configure. |
| all | Configure all ports. |
| enable | Enable VLAN Authorization on port. |
| disable | Disable VLAN Authorization on port. |
| tagged | Add port to egress of the VLAN-ID returned. |
| untagged | Add port to the untagged egress of the VLAN-ID returned. |
N/A.
None.
This example shows how to enable VLAN Authorization for port 1:1 for tagged packets:
# configure policy vlanauthorization port 1:1 enable tagged
This command was first available in ExtremeXOS 16.1.
